Wireless and RF
Acrylic paint effect on signal strength
Has anyone tested wireless signal strength when acrylic paint is placed in front of an AP? We are putting up some Belden BWIE-100 wireless enclosures in our new events center and our architectural team needs to paint a few of them so they blend in with the walls. I'm pretty sure they are using acrylic paint. I know that acrylic products hinder wireless signal, but I'm not sure how much. Any guidance is appreciated.
Re: Acrylic paint effect on signal strength
Greg - You may want to check out this thread regarding painting APs.
http://airheads.arubanetworks.com/vBulletin/showthread.php?t=964
