Good morning :
I need help for A.P. 85 and antenna 80 how could i obtain maximum power
thanks in advance
Re: Antenna
You can change the min tx eirp to the maximum in the Arm Profile for that ap group. Go to configuration> wireless> Ap configuration. Edit your AP-group. Expand RF management. Expand 802.11a or 802.11g radio profile. Click on Adaptive Radio management profile. Change the Min-TX-Eirp Value and the Max-TX-Eirp Value to the maximum.
Colin Joseph
Aruba Customer Engineering
