Change channel
Good evening :
How can i change the assigned channel manually ? and does ARM default parameters change assigned channel automatically when there is large traffic at the used channel ?
thanks in advance
Re: Change channel
ARM changes channel based on quite a few parameters, automatically. Please look here: http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=264 or search on the knowledgebase for ARM for more information.
