Contributor I
Enabling Mode Aware ARM
Does anyone know where I can enable mode aware arm as stated in the link below? I have navigated to the location stated in the doc, but I do not see a mode-aware option. I have a "client-aware" option only. Any help would be greatly appreciated.
http://airheads.arubanetworks.com/article/co-channel-interference-mitigation-using-arm
I am currently running v. 3.3.1.10
Re: Enabling Mode Aware ARM
ss1020,
I am ~99% sure the mode aware ARM appeared in 3.3.2.x code, so you would need to upgrade before it would be supported.
Contributor I
Thanks Olin.
I'll open a TAC case to have them verify.
