Wireless and RF
Finding sources of RF interference
Aruba is great at finding rogue APs but it does not indicate sources of wireless interference. The best thing that I know to find these sources of interference are spectrum analyzers. What are the best spectrum analyzers out on the market?
Are there any other tools other than spectrum analyzers that should be considered when trying to track down sources of interference?
Philip Smith
University of Windsor
Try WiSpy or Airview
For 2.4 try WiSpy or Ubiquti Airview.
JT
Regular Contributor I
Re: Finding sources of RF interference
I've been using AirMagnet for years, it's a great product... it's very detailed.
WiSpy 2.4x works well for very general RF analysis, great price. limited to 2.4Ghz only
$199 - http://www.metageek.net/
WiSpy DBx covers both bands, uses the same software as the 2.4x, more pricey but comparatively still cheap
$599 - http://www.metageek.net/
Ubiquit - never seen it but looks like a rebadged WiSpy sensor and software
AirMagnet Spectrum Analyzer, pretty pricey but TONS of info provided by the sensor, limited support for onboard WLAN nics for the general survey piece of the software
www.airmagnet.com (price varies, contact your local reseller)
Jerrod Howard
