Wireless and RF
Good average signal strength to aim for?
According to AMP, our average signal quality (across approx 60 users over 330 APs) is 35.42.
On any given day we probably have about 8 devices below 25 for signal quality.
What's your average and do you think equal to and above 30 is an acceptable level for decent performance?
Re: Good average signal strength to aim for?
Those numbers are fine, provided your clients are working fine and you don't have a large degree of interference raising the noise floor of your environment.
Jerrod Howard
Contributor I
I'd just add what I tell our users when they say they only have two (or one, etc) bars.
"How does it sound?"
