Occasional Contributor I
Guest wireless password
i am looking for an easy way to auto-change the password on my Guest wireless SSID. anyone know of any scripts available to do so? thanks in advance for all assistance.
Guest
Try here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=897
right but not what i meant
i do use kiwi , and i have plans to use it. however, my issue is with the internal database. i want to update it via the cli, and i don't think i have visibility into it in the cli? please assist. thanks again.
Re: Guest wireless password
You can use the "local-userdb-guest" CLI command to modify a guest user.
There are other options to modify from the CLI. Run the following command to see the options:
Hope that helps.
-Mike
