Wireless and RF
Manually Change Channel for AP
Hi everybody,
i would like to know if it is possible to manually change the channel for an AP and where to do that in the config.
Thank you for your help,
Jan
Frequent Contributor I
Re: Manually Change Channel for AP
It depents on the Release. What release you are use?
Best Regards
I am using 3.3.2.17
Jan
with Release 3 you have two possibilities.
1. Using AP groups where you are changing the RF Profile
2. Using AP specific Profiles where you are changing the RF Profile
I use Ap Groups. So i have one one Location 3 AP Groups where i use the same Profiles (aaa, ssid.....9 but every Group with a different RF Profile.
Best Regards
I use Ap Groups. So i have one one Location 3 AP Groups where i use the same Profiles (aaa, ssid..... but every Group with a different RF Profile.
Best Regards
I use Ap Groups. So i have on every Location 3 AP Groups where i use the same Profiles (aaa, ssid.....) but every Group with a different RF Profile.
Best Regards
I believe if you want to manually set channels, you'll have to turn off ARM.
No need for that... You can create two "channel domains" in one of which you can have some channels allowed in regulatory domain profile and in the other one you can have some other channels allowed.. So you can also have ARM features in this case...
