Mesh and wired AP´s
Hi, i have this question. Could be possible from a mesh point to connect another 2 wired ap´s using the rj-45 intfc. like a bridge and if possible what configuration issues will arise?.
Thanks in advance.
Re: Mesh and wired AP´s
You could go:
portal <-------mesh link -------> point -----wiredswitch----(qty2 APs)
Just fine, is that what you need?
Jerrod Howard
