Frequent Contributor II
Question: Re Max EIRP
As I understand it, Max EIRP is the maximum TX Power setting for an access point.
When I look at the setting for this on my controller I can choose a value which ranges from 3 to 127 yet when I look at the status of my access points in the monitoring/access points window, the table shows all my access points with a MaxEIRP of 23.5
If the MAX is set to 127 in the profile, should this not be what I am seeing from the monitoring/access points window on the controller.
Can someone explain to me how this EIRP/MaxEIRP relationship actually works?
Thanks.
Re: Question: Re Max EIRP
Thanks.
The monitoring page will show the MaxEIRP possible for that specific access point in your regulatory domain, as well as what is being output at the time. The 127 setting represents the literal maximum for whatever access point is connected and it will be different depending on the capability of that access point and what we are allowed output those channels in your regulatory domain. In that access point you are looking at, it is 23.5. The ARM settings do represent a range of what can be output, but the monitoring page shows what is ACTUALLY output.... if that makes sense.... ;)
Thanks Colin for that answer I get it now. :)
My next question is this. Hypothetically speaking, If one was trying to design a WLAN in which the AP's would on average run at 50% of their MAXEIRP, the best way to achieve this would be to deploy enough APs to allow ARM to adjust the power to the desired rate correct?
Hypothetically, yes. You should just plan for coverage and ARM will figure out the rest.
