Reduce signal strength
Have anyone know how i can reduce my AP signal strength? a bit lost when play around with the RF management profile. would appreciate if anyone can guide me.
Thank you.
Re: Reduce signal strength
Go to configuration> Wireless > AP Configuration. Expand to RF Managment. Expand the radio profile for the radio that you want and click on the ARM profile. Reduce the max-tx power parameter to what you want your maximum power to be.
