Roaming time
I'm trying to measure  roaming time. The client is on AP1 after reboot AP1 from the controller client is automatically connect to AP2 without any measurable roaming time. What's the reason ?
Thank you!
Re: Roaming time
You can measure roaming time by doing a simultaneous packet capture on both channels at the same time. That is the most definitive way of figuring it out.
