bg clients and AP 105
I have a customer where we installed rel 3.4.0.5.
After the upgarde the bg clients have problems connecting to the AP 105. They don't have any problem connecting to AP 61.
Used controllers are 3 SC-128 en 1 M3 controller.
Any ideas:confused:
Re: bg clients and AP 105
The AP105 is only supported on ArubaOS 3.4.1 and above http://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_adp.php?p_faqid=948
Contributor I
Will also run on 3.3.3.x
"To deploy an AP-105, the controller must run ArubaOS 3.3.3.x or
3.4.1.x."
Yes, but 3.4.0.x is not supported, is my point.
oeps the system is running 3.4.2.6! Sorry:rolleyes:
What kind of SSID are they attempting to connect to? Is it using encryption? Can other clients connect to the AP105? What clients CAN connect to the 105?
Open SSID and WPA2-AES
a clients can connect.
Can the b/g clients even see the wireless network? If not please open a case so that they can get to the bottom of this.
