Requirement:To be able to access Ble-console of an AP using BLUConsole app starting 8.6.X
Solution:From 8.6 BLE-opmode for ble-console operation been deprecated. We have to configure IOT radio profile to enable ble-console as it is disabled by default.
Configuration:Ble opmode been restricted to beacon, Scan and both.
(IoT Radio Profile "Test") # ble-opmode ?
<opmode> beac scan or both
In order to get the ble-console enabled we need to create IOT radio profile to have this option enabled,
(config) # iot radio-profile Test
(IoT Radio Profile "Test") # ble-console ?
<console> off on or dynamic
(IoT Radio Profile Test") # ble-console on
(IoT Radio Profile Test") # exit
(config)# exit
# commit apply
We need to map the profile in use using the below command,
(config) # iot use-radio-profile Test
(config)# exit
# commit apply
From running-configuration, you would be seeing the below config,
ble-console on
Verification# show ap debug ble-config
9c:8c:d8:cf:c6:86# show ap debug ble-config
---------- IOT Radio Profiles -----------------
Profile Name : Test
Radio Instance : Internal
Radio Mode : BLE
BLE Mode : beaconing scanning
BLE Console : On
BLE Tx Power (dBm) : 0
Note: No Zigbee service profiles configured.
Radio Configuration
Radio Information NORDIC ONBOARD Internal BLE Zigbee
Miscellaneous Configuration
Item Value
FIPS Mode No
Master IP 127.0.0.1
BLE Ready Yes
APB Info Update Intvl (in sec) 87 (430464/430414)
BLE debug log Enabled
Message Selector 0xffff (APB: 0xffff)
AP Deep Sleep Duration 120 minutes
AP USB Power Override Disabled (-1)
Uplink Status Up
APB Connection Status 0
Time Last Message to APB 1970-01-01 00:00:00
Log Levels Available { All(0x1fffff), Info(0x04), Warning(0x02), Error(0x01), Ageout(0x08), BMReq(0x10), FW-Upgrade(0x20), FW-UpgradeErr(0x40), CfgUpdate(0x80), CfgUpdateErr(0x100), Beacon(0x200), BcnTLV(0x400), BcnErr(0x800), APB(0x1000), Tags(0x2000), ZF(0x4000), AMON(0x8000), IOT-GW(0x10000), AT-HTTPS-JSON(0x20000), AT-WEBSOCKET-PROTOBUF(0x40000), Enocean(0x100000), (0x00), None(0x00) }
Current Log Level { 0x901e1 : Error(0x0001), FW-Upgrade(0x0020), FW-UpgradeErr(0x0040), CfgUpdate(0x0080), CfgUpdateErr(0x0100), IOT-GW(0x10000) }
Log Mac Filter None
Note: No IoT transport context configured. Config ID:0
Note: Uplink status is applicable only for Controller with Dynamic Console operational mode.
For APBs of type LS-BT1USB, applied operational mode is Beaconing if ap system profile setting is either Persistent or Dynamic.
Note: Setting Message Selector value to 0x0 will cause the APB to function improperly. Use the knob with caution.
Note: Message Selector Bits: All(0xffff), V0 Scan (0x01), V1 Scan (0x02), UI Scan (0x04), Proximity Advert (0x08), IBeacon (0x10), Heartbe
at-1 (0x20), Heartbeat-UI (0x40), Upg Ack (0x80), Heartbeat-2 (0x200), Generic Scan (0x400), Generic Advert (0x800), Tag V1 Scan (0x1000), Tag V1 Advert (0x2000)
9c:8c:d8:cf:c6:86# show ap deb ble-database
BLE APB Information
AP Name AP Group BLE MAC BLE Cur. Bank BLE Opp. Bank AP Eth MAC AP IP Reported at ConfigID Status
9c:8c:d8:cf:c6:86 20:4c:03:45:c6:e8 DFU APP 1.3-53 DFU BL 0.0-0 9c:8c:d8:cf:c6:86 127.0.0.1:8514 2020-05-19 19:17:17 0 Current
Total AP BLE devices reported:1
Note:'Status' column indicates whether information received for an AP's
: BLE radio is 'Current' (message received in the last 10 minutes)
: or 'OutOfDate' (message received more than last 10 minutes ago and/or AP might be down).
9c:8c:d8:cf:c6:86# show ap debug ble-table
BLE Device Table [APBs]
MAC HW_Type FW_Ver Flags Status Radio Type Major# Minor# UUID Meas. Pow. Tx_Power Last Update Uptime
20:4c:03:45:c6:e8 BT-AP550 DFU App 1.3-53 0x0183 LIA Internal 0 0 4152554E-F99B-4A3B-86D0-947070693A78 -56 7 2s 23h:40m:40s
BLE Device Table [Aruba Beacons]
MAC HW_Type FW_Ver Flags Status Batt(%) RSSI Major# Minor# UUID Meas. Pow. Tx_Power Last Update Uptime
20:4c:03:3e:de:24 BT-AP510 DFU App 1.3-32 0x0183 IA ONBOARD -87 16005 24699 4152554E-F99B-4A3B-86D0-947070693A78 -56 15 I:1239s 1h:30m:30s
20:4c:03:3e:de:26 BT-AP510 DFU App 1.3-32 0x0183 IA ONBOARD -84 16005 24692 4152554E-F99B-4A3B-86D0-947070693A78 -56 15 I:2s 1h:49m:0s
20:4c:03:3e:de:29 BT-AP510 DFU App 1.3-32 0x0183 IA ONBOARD -67 16005 24700 4152554E-F99B-4A3B-86D0-947070693A78 -56 15 I:0s 1h:55m:30s
20:4c:03:3e:de:2e BT-AP510 DFU App 1.3-32 0x0183 IA ONBOARD -84 16005 24693 4152554E-F99B-4A3B-86D0-947070693A78 -56 15 I:1239s 1h:31m:0s
20:4c:03:3e:de:34 BT-AP510 DFU App 1.3-32 0x0183 IA ONBOARD -93 16005 24702 4152554E-F99B-4A3B-86D0-947070693A78 -56 15 I:67s 1h:28m:30s
20:4c:03:3e:de:37 BT-AP510 DFU App 1.3-32 0x0183 IA ONBOARD -81 16005 24696 4152554E-F99B-4A3B-86D0-947070693A78 -56 15 I:1237s 1h:32m:0s
20:4c:03:3e:de:38 BT-AP510 DFU App 1.3-32 0x0183 IA ONBOARD -75 16005 24691 4152554E-F99B-4A3B-86D0-947070693A78 -56 15 I:1s 2h:2m:30s
20:4c:03:3e:df:2e ARUBA OAD A 1.3-24 0x0001 A -- -71 0 0 -- -- I:161s 30s
Beacons:8
Total BLE devices:8
Note: Battery level for LS-BT1USB devices is indicated as USB.
Note: Uptime is shown as Days hour:minute:second.
Note: Last Update is time in seconds since last heard update.
Note: Meas. Pow. is the averaged RSSI (in dBm) when the iBeacon is calibrated.
Status Flags:L:AP's local beacon; I:iBeacon; A:Beacon management capable
:H:High power beacon; T:Asset Tag Beacon; U:Upgrade of firmware pending
:u:Beacon management update received
