Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Technical Product Details
Community Learning
News
Events
Search
Blog Viewer
Controller-less WLANs
Community Home
Discussion
0
Library
0
Members
11
last person joined: 12 days ago
IAP, Central, MSR, Outdoor Mesh
How routing lookup will work with/without DPS policy & PBR
By
esupport
posted
Aug 05, 2020 08:56 AM
Options Dropdown
Mark as Inappropriate
0
Kudos
Q:
A:
Without any DPS policy and no PBR configured:
Route lookup will be based on Equal-cost multi-path (ecmp ) routes and their cost.
Lowest cost route is preferred.
If there multiple routes with equal cost, round robin algorithm is applied among these routes.
With DPS policy configured, but no PBR configured:
VPN peer IP address will be the gateway for routes in branch controller.
Each VPN peer will be reachable through one or more wan uplinks.
If two or more VPN peers are in Active-Active mode, all the ipsecmaps over, all reachable uplinks to the respective VPN peers have to be considered.
SDWAN policy might filter out certain wan links or wan link types based on the policy and SLA conditions.
Uplink load balance algorithm will be applied on the filtered routes
With no DPS policy configured, but PBR configured:
PBR will decide the routing
With DPS policy configured and PBR configured:
PBR provides the possible routes based on the traffic match.
If there is DPS policy match and if the DPS suggested WAN links’ routes are same or subset of PBR suggested routes, then DPS policy will be applied.
If DPS and PBR policy match but uplink not match then traffic will dropped.
Reason for Moderation
Describe the reason this content should be moderated (required)
Permalink
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2021 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
