Clone AP Configuration
By alc posted Jun 17, 2013 02:34 PM
Symptoms
I am trying to clone the configuration from one AP to another. Im running this command
conf t
ap-name AP01
clone AP02
and then i get this message "AP name 'AP02' undefined"
Am i missing something to run this command? It's between two RAP5 and im running version 6.1.2.4 and even tried on a 6.2.0.2 version.
Diagnosis
The reason why I want to clone the configuration from one RAP5 to another is because that RAP5_01 works with a 3g dongle and i want RAP5_02 to have the same configuration to work with a 3g dongle as well.
So copying the AP-group wont work in this case.
Solution
The 3g/4g card configuration is not located on the controller.  It is programmed into the flash of individual devices.  If you want to program them into multiple devices, you can use a provisioning profile:
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1216
1 view
