How do I convert an IAP to standalone using the CLI?
By Shyam_Moolayilkalarikkal posted Jul 04, 2014 05:17 PM
Question: How do I convert an IAP to standalone using the CLI?
Product and Software: This article applies to all Aruba Instant platforms and versions.
Bring up the Aruba Instant AP (IAP) on the network so that it gets the configuration from the IAP that is acting as the virtual controller. Then you can configure the IAP in "standalone" mode at the apboot prompt by issuing the following command:
apboot> setenv standalone_mode 1
apboot> save
apboot> printenv
bootdelay=2
baudrate=9600
autoload=n
boardname=Talisker
servername=aruba-master
bootcmd=boot ap
autostart=yes
bootfile=mips32.ari
ethaddr=00:24:6c:c0:3d:4d
ethact=eth0
netmask=255.255.255.0
gatewayip=10.10.10.1
name=AP2
dnsip=8.8.8.8
domainname=arubanetworks.com
ipaddr=10.10.10.100
os_partition=0
wifi1_arm_channel=6
wifi1_arm_power=12
wifi0_arm_channel=36
wifi0_arm_power=10
standalone_mode=1
<<<<<<<<<<<<<<<<<Standalone mode configuration
stdin=serial
stdout=serial
stderr=serial
apboot> boot <<<<<<<<<<<<To boot the AP with the above configuration
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
ELF file is 32 bit
Loading .text @ 0x80e00000 (6031160 bytes)
Loading .data @ 0x813c0740 (32 bytes)
Clearing .bss @ 0x813c0760 (16 bytes)
## Starting application at 0x80e00000 ...
Uncompressing.........................................................
þ
Aruba Networks
ArubaOS Version 6.1.3.1-3.0.0.0 (build 33460 / label #33460)
Built by p4build@crete on 2012-04-26 at 06:05:05 PDT (gcc version 4.3.3)
CPU Rev: aa
71x CPU
Flash variant: default
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 120704k/131072k available (1865k kernel code, 10276k reserved, 694k data, 5128k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=25284096
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ..................................................................................................................................................................................................................................................................................................................................................................................................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Talisker RSSI LED initialization
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
.<6>lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Domain Name: arubanetworks.com
No panic info available
Testing TPM... Passed
ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count 400
AG7100: Max rx descriptor count 252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: 00:24:6c:c0:3d:4d
ATHRF1: Port 0, Neg Success
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
wifi uplink not present...
Starting up in standalone mode
AP xml model 39, num_radios 2 (jiffies 6911)
init_asap_mod: installation:0
radio 0: band 1 ant 0 max_ssid 8
radio 1: band 0 ant 0 max_ssid 8
election init: rand=11 HZ=500
setting bond0 as bridge child
setting gre0 as split child
Starting watchdog process...
Got all network ag7100_ring_alloc Allocated 4800 at 0x80396000
params from APboag7100_ring_alloc Allocated 3024 at 0x80ab6000
AG7100: cfg1 0x7 cfg2 0x7014
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
AG7100: unit 0: phy not up carrier 1
Writing 4
ADDRCONF(NETDEV_UP): bond0: link is not ready
ot env. Skipping DHCP
10.10.10.100 255.255.255.0 10.10.10.1
Starting Webserver
bind: Transport endpoint is not connected
NTP Server not saved in flash... using default
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_rate_atheros: Aruba Networks Rate Control Algorithm
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_spectrum: Version 2.0.0
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_ahb: 0.9.4.5 (Atheros/multi-bss)
ath_pci: 0.9.4.5 (Atheros/multi-bss)
wifi0: Base BSSID 00:24:6c:83:d4:d8, 8 available BSSID(s)
bond0 address=00:24:6c:c0:3d:4d
br0 address=00:24:6c:c0:3d:4d
wifi0: AP type AP-105, radio 0, max_bssids 8
wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
AG7100: pll reg 0x18050010: 0x110000 AG7100: cfg_1: 0x1ff0000
AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0xfffef
AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
wifi1: Base BSSID 00:24:6c:83:d4:d0, 8 available BSSID(s)
wifi1: AP type AP-105, radio 1, max_bssids 8
wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
Starting FIPS KAT ... Completed FIPS KAT
AP rebooted Sat Jan 1 00:03:14 UTC 2000; User reboot
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
ip_time_handler: Got ip and packets on bond0 Started master election 2-0
asap_send_elected_master: sent successfully
User: asap_send_elected_master: sent successfully
i am a potential master now
i am a master now
<<<<<<<<<<<<<<<Standalone AP is own master now
