Q: What is the command to verify the different profiles mapped/provisioned to an Access Point?
A: The Aruba Access Points will be provisioned to an AP group which has all the information however in some scenarios we would need to configure some specific configurations to an specific Access Point, in order to verify the profiles being used by that Access Point we can use the below command.
(Aruba7210) #
(Aruba7210) #show ap profile-usage ap-name 18:64:72:cd:c8:ba
AP "18:64:72:cd:c8:ba" Profiles
Profile Type Profile Source
AP system profile default ap-group "WebTest" ap-system-profile
Regulatory Domain profile default ap-group "WebTest" regulatory-domain-profile
RF Optimization Profile default ap-group "WebTest" rf-optimization-profile
RF Event Thresholds Profile default ap-group "WebTest" event-thresholds-profile
IDS General Profile default ids profile "default" general-profile
IDS Unauthorized Device Profile default ids profile "default" unauthorized-device-profile
IDS Profile default ap-group "WebTest" ids-profile
ARM RF domain default ap-group "WebTest" arm-rf-domain-profile
VoIP Call Admission Control profile default ap-group "WebTest" voip-cac-profile
AP group WebTest
AP "18:64:72:cd:c8:ba" Radio 0 Profiles
802.11a radio profile default ap-group "WebTest" dot11a-radio-profile
Adaptive Radio Management (ARM) profile default rf dot11a-radio-profile "default" arm-profile
High-throughput radio profile default-a rf dot11a-radio-profile "default" ht-radio-profile
AM Scanning profile default rf dot11a-radio-profile "default" am-scan-profile
AP "18:64:72:cd:c8:ba" BSSID 18:64:72:5c:8b:b0 Profiles
802.11K Profile default wlan virtual-ap "WebTest" dot11k-profile
Handover Trigger Profile default wlan dot11k-profile "default" handover-trigger-profile
RRM IE Profile default wlan dot11k-profile "default" rrm-ie-profile
Beacon Report Request Profile default wlan dot11k-profile "default" bcn-rpt-req-profile
TSM Report Request Profile default wlan dot11k-profile "default" tsm-req-profile
SSID Profile WebTest wlan virtual-ap "WebTest" ssid-profile
High-throughput SSID profile default wlan ssid-profile "WebTest" ht-ssid-profile
Virtual AP profile WebTest ap-group "WebTest" virtual-ap
AAA Profile WebTest wlan virtual-ap "WebTest" aaa-profile
AP "18:64:72:cd:c8:ba" Radio 1 Profiles
802.11g radio profile default ap-group "WebTest" dot11g-radio-profile
Adaptive Radio Management (ARM) profile default rf dot11g-radio-profile "default" arm-profile
High-throughput radio profile default-g rf dot11g-radio-profile "default" ht-radio-profile
AM Scanning profile default rf dot11g-radio-profile "default" am-scan-profile
AP "18:64:72:cd:c8:ba" BSSID 18:64:72:5c:8b:a0 Profiles
AP "18:64:72:cd:c8:ba" Ethernet 0 Profiles
AP Ethernet Link profile default ap wired-port-profile "default" enet-link-profile
AP LLDP Profile default ap wired-port-profile "default" lldp-profile
AP wired port profile default ap-group "WebTest" enet0-port-profile
AP "18:64:72:cd:c8:ba" Ethernet 1 Profiles
AP wired port profile default ap-group "WebTest" enet1-port-profile
AP "18:64:72:cd:c8:ba" Ethernet 1 Wired AP Profiles
Wired AP profile default ap wired-port-profile "default" wired-ap-profile
(Aruba7210) #
