How to configure Captive Portal for Guest Access on a Remote AP (Virtual Branch Networks)? Can Captive Portal be used on a Remote AP? Can Captive Portal be used for an user in bridge mode in a Remote AP?
By Arunkumar posted Jun 30, 2014 09:22 PM
Product and Software: This article applies to all Aruba controller running the RN branch of software version 3.0 and above, with all Aruba AP supporting Remote AP functionality.
Overview
Captive Portal is used frequently in a campus AP environment to provide wireless access for guest users.  The same functionality can be extended to the Virtual Branch Networks (VBN) environment. Typically, a wireless SSID (virtual AP) used for guest access in a Remote AP (RAP) is configured in 'bridge' mode (traffic routed locally).  However, the Aruba captive portal is hosted on the controller only. Therefore, an user associated to an SSID in bridge mode (forwarding mode) will not be able to reach the captive portal pages hosted on the controller.  In order to get around this, the SSID must be set-up in 'split-tunnel' mode.
This article describes how a guest captive portal can be set-up on a RAP at the same time not compromising security of corporate-bound traffic.
Details
Below please find the detailed configuration steps (using CLI) for setting up a captive portal for a guest SSID on a RAP.  This set-up has the following characteristics:
1) The Guest SSID does not employ any wireless encryption (open system).  Changing this to use pre-shared key is trivial and will be left to the readers.
2) Guests users are placed in a private VLAN which is isolated from normal corporate users.  Private IP addresses are assigned by a DHCP server on the controller.
3) The Captive Portal is hosted on the controller where the RAP is terminated.  It can be further customized (please refer to ArubaOS User Guide for details).  Authentication of captive portal users are by the userid and password stored in the Internal DB.
4) Prior to authentication (with Captive Portal), guest users are placed in a quarantined role with access only to the captive portal on the controller.
5) After authentication, users are placed in a role where all traffic are routed locally out to the Internet from the up-link port of the RAP, with exception to make provision for the user to log-out.  All traffic is sourced-NATted to the IP address of the uplink port of the RAP.  This ACL can be further customized to limit traffic to a small subset of allowed protocols (e.g. dns, http and https only).
Configuration Steps
[Note that the IP addresses in the following config example are specific to a test set-up. ]
Configure an alias containing the IP addresses of the DNS servers at corporate.  For captive portal to function properly, DNS servers must be used initially.  However, a local DNS server can be used (with the Split DNS feature) post-authentication.
netdestination corp-dns-servers
  host 10.1.1.50
  host 10.1.1.200
Set-up a private VLAN and IP address.  In order for a user to reach the DNS user, src-nat must be set-up
vlan 21
interface vlan 21
        ip address 192.168.199.1 255.255.255.0
        ip nat inside
Set-up two ACL's and the initial role (pre-authentication) of the guest user.  These ACL's will only allow essential traffic to get through to the controller.  Also, a captive portal profile is configured for this initial role.
ip access-list session vbn-guest-control
  user any udp 68 deny
  any any svc-dhcp permit
  any any svc-dns permit
  any any svc-icmp permit
ip access-list session vbn-guest-captiveportal
  user   alias controller svc-https dst-nat 8081
  user any svc-http dst-nat 8080 log
  user any svc-https dst-nat 8081
aaa authentication captive-portal "vbn-guest"
   default-role "vbn-guest"
user-role vbn-guest-logon
 captive-portal vbn-guest
 session-acl vbn-guest-control
 session-acl vbn-guest-captiveportal
Set-up the ACL for the authenticated guest user.  Note that this role would src-nat all traffic locally with the exception to allow user to 'logout'
 user   alias corp-dns-servers svc-dns permit
 user any any route src-nat
user-role vbn-guest
Tying them all together with the necessary AAA, Virtual-AP, and SSID profiles.
aaa profile "vbn-guest"
   initial-role "vbn-guest-logon"
wlan ssid-profile "vbn-guest"
   essid "Guest"
wlan virtual-ap "vbn-guest"
   vlan 21
   forward-mode split-tunnel
   aaa-profile "vbn-guest"
Enable the 'Split-DNS' function.  Only domain names matching 'arubanetworks.com' would be sent to the DNS servers at corporate. All other DNS queries would go to the local DNS servers.  Please ensure that this matches the CN name of the SSL certificate on the Aruba controller.
ap system-profile <AP-System-Profile>
  dns-domain "arubanetworks.com"
Adding this Virtual AP to any AP group where this SSID is needed.
ap-group <AP-Group>
   virtual-ap <other VAP>
   ap-system-profile <AP-System-Profile>
Operation
- When a user associate to this Guest SSID, would be placed in the 'vbn-guest-logon' role where all HTTP/HTTPS traffic is re-directed to the captive portal on the controller via the IPSec tunnel between the RAP and the controller.
- Users authenticates using the Internal DB.
- Users authenticated successfully would be placed in the 'vbn-guest' role were most traffic are routed (src-nat) locally.
- Users will idle-out normally or can log-out manually using the standard logout button.
Resources
1. Validated Referene Design for Virtual Branch Networks contains detailed information on the different forwarding modes as well as steps for trouble-shooting.
