ArubaOS-Switch / Aruba Mobility-Controller – How to Configure IGMP Protocol
By esupport posted Apr 21, 2020 05:14 PM
AOS Mobility Controller and ArubaOS Switch
In the following example, IGMP is configured on an AOS mobility controller and an ArubaOS switch.
---------- Mobility Controller Configuration ----------
(StandaloneVMC) [mynode] (config) #ip igmp
(StandaloneVMC) ^[mynode] (config-submode)#interface vlan 108
(StandaloneVMC) ^[mynode] (config-submode)#ip igmp proxy gigabitethernet 0/0/0
(StandaloneVMC) ^[mynode] (config-submode)#write memory
Saving Configuration...
Configuration Saved.
---------- Switch Configuration ----------
Core-Switch# show running-config vlan 108
Running configuration:
vlan 108
   name "Standalone-VMC"
   tagged 9
   ip address 10.0.108.1 255.255.255.0
   ip igmp
---------- Mobility Controller Verification ----------
StandaloneVMC) [mynode] #show ip igmp interface vlan 108
IGMP Interface Table
VLAN   Addr              Netmask          MAC Address          Snooping    Querier             Querier-dest  IGMP Proxy
108    10.0.108.100  255.255.255.0  00:0c:29:a1:e3:16  disabled      10.0.108.100    local               enabled
---------- Switch Verification ----------
Core-Switch# show ip igmp vlan 108
 IGMP Service Protocol Info
  Total VLANs with IGMP enabled                      : 1
  Current count of multicast groups joined     : 1
  IGMP Filter Unknown Multicast: Disabled
  IGMP Filter Unknown Multicast Status: Disabled
  VLAN ID : 108
  VLAN Name : Standalone-VMC
  IGMP version : 2
  Querier Address [this switch ] : 10.0.108.1
  Querier Port :
  Querier UpTime : 1h 13m 2s
  Querier Expiration Time : 0h 1m 32s
  Active Group Addresses   Type            Expires          Ports      Reports   Queries
  239.0.82.11                        Filter            0h 3m 37s       9            37             0
Core-Switch(config)# show ip igmp vlan 108 group 239.0.82.11
 IGMP ports and group information for group 239.0.82.11
 VLAN ID: 108
 Uptime: 3h 15m 28s
 Last Reporter: 10.0.108.100
 Type: Filter
  Port    Port Type       Port Mode     Expires      Access
  9         1000T              Auto               208             host
