Q: How does the certificate chaining should be done for Instant AP?
A: The Certicate chaining should be done as below:
-----BEGIN CERTIFICATE-----
Public signed Key
-----END CERTIFICATE-----
Intermediate Primary CA
Intermediate Secondary CA
Root CA
-----BEGIN PRIVATE KEY----
Private Key
-----END PRIVATE KEY-----
If the certificate chain is not uploaded with the above order for the captive portal server then WEBUI becomes inaccessible, as WEBUI will also use the same certificate uploaded for captive portal server and only way to recover is to clear the cp-cert from the CLI.
To clear the certificate from the CLI using command "clear-cert cp". Once the custom certificate is removed, IAP will use the default self-signed certificate for WEBUI.
