ZTP ports on SDWAN Gateways
By esupport posted Jan 01, 2020 09:34 PM
Q:
Supported Zero touch provisioning ports for SD-WAN Gateways
A:
Note:
  • The last copper port on the gateway is reserved for ZTP if it is running the firmware image shipped from the factory(Non SD-WAN image Example : 6.5.x.x
  • ZTP not supported on USB LTE, PPoE on Non-SDWAN image.
  • The automatic firmware upgrade from Activate is supported for Aruba gateways running the factory firmware with image 6.5.1.4 and above.
  • If the gateway is running ArubaOS 8.0.x.x or above then a manual firmware upgrade is required.
  • GE0/0/1 would act as "service port", and provide a UI-based workflow to provision the gateway.
