How to change the strength of a cipher suite on an Aruba Controller?
By esupport posted Apr 03, 2017 02:40 AM
Q:
A:
We can change the strength of the cipher suite on an Aruba Controller as below.
(ArubaMaster) #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(ArubaMaster) (config) #web-server profile
(ArubaMaster) (Web Server Configuration) #ciphers ?
high                    encryption keys larger than 128 bits
low                     56 or 64 bit encryption keys
medium                  128 bit encryption keys
(ArubaMaster) (Web Server Configuration) #ciphers medium
(ArubaMaster) #
Note: The default strength of the cipher suite is set to high.
