Q: How to find the database table size in Airwave for a specific table?
A: We could execute the command below in the Airwave CLI to find the size of a specific table:
# dbc "select pg_size_pretty(pg_total_relation_size('ap'));
The above command will show the size of the ap table, as shown in the example output below:
[root@localhost mercury]# dbc "select pg_size_pretty(pg_total_relation_size('ap'));"
pg_size_pretty
272 kB
(1 row)
However, if we want to see the size of all the tables individually, we could run the below command:
# dbsize
This command will list out the table name's and their size's, individually.
Note: The list will be big, might not be easy to read in the single window, we could use the flags like "# dbsize | more" or "# dbsize | less" to see the list in pages or we could also pipe the output to a text file, by running the command # dbsize > /tmp/<anyfilename.txt>
