On Aruba Controller can only the audit-trail logs be sent to the syslog server?
By Shyam_Moolayilkalarikkal posted Nov 17, 2014 05:38 PM
Question: On Aruba Controller can only the audit-trail logs be sent to the syslog server?
Environment: This article applies to the Aruba Controller deployments where syslog server is used as logging server.
Generally, when syslog server is configured as logging server, all the logs including debug logs are pushed to the server. And, when it comes to dense deployments, more and more logs gets pushed consuming space on the servers.
Some administrators, would be interested to keep a track of only the configurations that had been made on the controller.  The image below helps to do the same:
As show below, the audit trail information is sent to "Local1" at "Notice" Level.
Config changes made on the controller sent to syslog server as show in the below images,
Note: Configuration screenshot along with syslog server output has been added to add clarity for the customers.
1 comment
Comments
Jan 04, 2018 12:43 AM
Unable to see all option under category hence unable to forward logs to syslog. Could you please share steps to enable that option.
