Why do I run into problems when I bridge two VLANs into the same subnet/domain?
By default, the VLANs on the switch all share the same MAC address. This can cause issues when bridging multiple VLANs into the same subnet. You can manually change the VLAN MAC address using the following command:
vlan <x> ip-recv-mac-address xxxxxx-xxxxxx
Solution: Try changing the MAC address on one or both VLANs to a unique address.
Example: Port 1 is a member of VLAN 48. Port 2 is a member of VLAN 49. Ports 1 and 2 are bridged together into the same subnet.
Manually change the VLAN MAC address to a unique address: vlan 48 ip-recv-mac-address 665544-332211 vlan 49 ip-recv-mac-address 665555-444444
This allows both VLANs to carry traffic for the same subnet without having ARP issues.
© Copyright 2021 Hewlett Packard Enterprise Development LPAll Rights Reserved.
