When do we see "mic failure" and "Ptk Challenge Failed" for a client on PSK SSID?
By arunhasan1 posted Apr 08, 2015 02:16 PM
We have a PSK based SSID. All the client connect fine except a few. They show both the following errors"
1. "mic failures" in auth tracebuf.
2. "Reason Ptk Challenge Failed" in user debug.
What could be the reason behind this.
Environment : This article applies to all Aruba controllers and os versions.
we can create a preshared key based SSID on Aruba controller. This SSID will encrypt all the user traffic to the AP however it doesn't require a back-end authentication server.
Requirements:
1. A dummy dot1x profile is mapped in the aaa profile:
2. Then we need to give passphrase and opmode on the SSID profile:
3. After this, we can see that the SSID is now PSK based:
4. The same passphrase must be given in the client machine.
5. When all the parameters are correct, we see the following:
(ArubaController1) (config) #show auth-tracebuf mac a4:4e:31:75:0b:fc count 30
Auth Trace Buffer
Jan  5 05:35:18  wpa2-key1             <-  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  117
Jan  5 05:35:18  wpa2-key2             ->  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  119
Jan  5 05:35:18  wpa2-key3             <-  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  151
Jan  5 05:35:18  wpa2-key4             ->  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  95
6. However, if we have a PSK mismatch on the controller and the client machines, we will see the MIC failure on key2 transaction:
(ArubaController1) #show auth-tracebuf mac a4:4e:31:75:0b:fc count 30
Auth Trace Buffer
Jan  5 05:38:42  station-down           *  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  -
Jan  5 05:38:42  station-up             *  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  -    wpa2 psk aes
Jan  5 05:38:42  wpa2-key1             <-  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  117
Jan  5 05:38:43  wpa2-key1             <-  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  117
Jan  5 05:38:43  wpa2-key2             ->  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  119  mic failure
Jan  5 05:38:44  wpa2-key1             <-  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  117
Jan  5 05:38:44  wpa2-key2             ->  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  119  mic failure
Jan  5 05:38:45  wpa2-key1             <-  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  117
Jan  5 05:38:45  wpa2-key2             ->  a4:4e:31:75:0b:fc  9c:1c:12:b9:76:13  -  119  mic failure
7. In the user debug we see the following:
show log all | include a4:4e:31:75:0b:fc
Jan  5 05:39:25  stm[1136]: <501000> <DBUG> |AP 9c:1c:12:c3:97:60@192.168.30.3 stm|  Station a4:4e:31:75:0b:fc: Clearing state
Jan  5 05:39:25  stm[1136]: <501105> <NOTI> |AP 9c:1c:12:c3:97:60@192.168.30.3 stm|  Deauth from sta: a4:4e:31:75:0b:fc: AP 192.168.30.3-9c:1c:12:b9:76:13-9c:1c:12:c3:97:60 Reason Ptk Challenge Failed
Jan  5 05:39:25  stm[2131]: <501000> <DBUG> |stm|  Station a4:4e:31:75:0b:fc: Clearing state
Jan  5 05:39:25  stm[2131]: <501080> <NOTI> |stm|  Deauth to sta: a4:4e:31:75:0b:fc: Ageout AP 192.168.30.3-9c:1c:12:b9:76:13-9c:1c:12:c3:97:60 Ptk Challenge Failed
Jan  5 05:39:25  stm[2131]: <501106> <NOTI> |stm|  Deauth to sta: a4:4e:31:75:0b:fc: Ageout AP 192.168.30.3-9c:1c:12:b9:76:13-9c:1c:12:c3:97:60 wifi_deauth_sta
Jan  5 05:39:34  stm[1136]: <501044> <NOTI> |AP 9c:1c:12:c3:97:60@192.168.30.3 stm|  Station a4:4e:31:75:0b:fc: No authentication found trying to de-authenticate to BSSID 9c:1c:12:b9:76:13 on AP 9c:1c:12:c3:97:60
Jan  5 05:39:34  stm[1136]: <501105> <NOTI> |AP 9c:1c:12:c3:97:60@192.168.30.3 stm|  Deauth from sta: a4:4e:31:75:0b:fc: AP 192.168.30.3-9c:1c:12:b9:76:13-9c:1c:12:c3:97:60 Reason Denied: AP Ageout
Jan  5 05:39:34  stm[1638]: <501080> <NOTI> |stm|  Deauth to sta: a4:4e:31:75:0b:fc: Ageout AP 192.168.30.3-9c:1c:12:b9:76:13-9c:1c:12:c3:97:60 Denied: AP Ageout
8. Most new client supplicants will ask for new PSK if it is mismatched but some client wont. To resolve this, we need to make sure that the preshared-keys are same on both the controller and the client.
ON a PSK SSID, if we see the following for the same client:
It usually means that there is a passphrase mismatch and we need to fix the same.
1 comment
Comments
Jun 19, 2015 04:23 AM
If this happens intermittently once a week, what could be the issue? ____
Does wpa-key period help in the resolution, if the issue happen occasionally? ____
