How do I configure VLAN pooling in Aruba Instant?
By Arunkumar posted Jul 02, 2014 07:52 PM
This article explains:
1. Need for VLAN Pooling in IAP
2. Configuring VLAN Pool in IAP
4. What we cannot achieve using VLAN pooling
VLAN Pooling is a new feature added in OS version 6.2.0.0_3.2.0. Any version prior to this does not have the VLAN Pooling feature.
In a single IAP cluster, there can be a large number of clients in the same VLAN. This leads to a high level of broadcasts in the same subnet. The solution to this is to partition the network into reasonably-sized subnets and use L3-mobility between those subnets, when clients roam. However, there are various situations, like simple network design considerations, where a large number of clients need to be in the same subnet. VLAN pooling provides a solution in such scenarios. Each client is randomly assigned a VLAN from a pool of
VLANs on the same SSID, thereby automatically partitioning a single broadcast domain of clients into multiple VLANs.
VLAN Pooling ensures client gets the same VLAN across all APsin the cluster.
NOTE: VLAN Pooling and L3 Mobility cannot be used together. Also, random VLAN assignment
algorithm does not ensure even distribution of clients.
Environment : This article applies to all IAPs running OS version 6.2.0.0_3.2.0.
Navigate to New WLAN > VLAN tab > Static > Assign VLAN ID
Client VLAN assignments can be viewed in CLI and in Support UI by checking the AP association table
2 comments
1 view
Comments
Jul 22, 2014 05:20 PM
"Named VLAN" is not supported in Instant. As shown in the above screen shot, we can only list the VLAN ID's.
Jul 22, 2014 03:34 AM
We can define a vlan pool with a pool name, and assign the pool name in the VLAN 'box', right?
