Q: Does the "Service-type" attribute in Radius Auth request changes based on the Authentication method?
A: Does the "Service-type" attribute in Radius Auth request changes based on the Authentication method?
Starting from 6.4.3.0 AOS, the Service-Type attribute values in RADIUS authentication requests changes as per the Authentication methods (MAC, dot1x and Captive portal)
Service-type = Call-Check (MAC auth)
Service-type = Framed (802.1X auth)
Service-type = Login (Captive portal auth)
For MAC auth, the service-type is set to Call-Check.
For Dot1x auth, the service-type is set to Framed.
For Captive portal auth, the service-type is set to Login.
