Checklist for adding APs
By AnandKumar Sukumar posted Jul 03, 2014 03:04 PM
Aruba MAC OUIs and supported versions
Aruba MAC OUISupported Versions
00:0B:86
  • All versions
00:24:6C
  • AOS 3.3.1.28 and later
  • AOS 3.3.2.14 and later
  • ArubaOS-FIPS : 3.3.2.14-FIPS and later
D8:C7:C8
  • AOS 3.3.3.10 and later
  • AOS 3.4.4.1 and later
  • AOS 5.0.3.0 and later
  • ArubaOS-FIPS : 3.3.2.21-FIPS and later
  • ArubaOS-FIPS : 3.4.4.0-FIPS and later
6C:F3:7F
  • AOS 3.4.5.1 and later
  • AOS 5.0.4.1 and later
  • AOS 6.0.2.1 and later
  • AOS 6.1.2.3 and later
  • ArubaOS-FIPS : 3.4.5.1-FIPS and later
24:DE:C6
  • AOS 5.0.4.8 and later
  • AOS 6.1.3.5 and later
  • AOS 6.2.0.0 and later
9C:1C:12
  • AOS 5.0.4.10 and later
  • AOS 6.1.3.6 and later
  • AOS 6.2.0.1 and later
  • AOS 6.3.0.0 and later
  • ArubaOS-FIPS : 6.1.4.4-FIPS and later
Workaround:
On controllers running AOS SW releases 5.0 or newer there is an option to add new OUI to "valid-network-oui" profile. Below are the steps:
CLI:
configure terminal
     valid-network-oui-profile oui <OUI value>
end
Example
(3600_Controller) #show valid-network-oui-profile
Valid Equipment OUI profile
Parameter  Value
OUI        9C:1C:12
Web UI:
On controllers running AOS SW releases 5.0 or newer,
Go to the "Configuration" tab. Click on the "All Profiles" option under the "Advanced Services"
In the Profiles, click on "Controller" --> "Valid Equipment OUI" --> Enter the OUI and click on Add and then Apply.
Interoperability between new TPM part and certain SW versions
TPM module on AP-104/5 was updated because of component obsolescence – field bulletin - AP1306–2.
Determine if your system is affected by the problem:
  • Any AP-104/105, IAP-104/105 with serial number between BT0308241 and BT0309240 or BT0553579 and higher,
  • Using ArubaOS software 6.0.0.0 through 6.1.3.0 (inclusive) or ArubaInstant software 6.1.2.3-2.x.y.z
If affected, upgrade the software to:
  • ArubaOS: 6.1.3.1 or later, latest GA release recommended, or
  • Aruba Instant: 6.1.3.1-3.0.0.0 or later, latest GA release recommended
