Prerequisites:
In order to provision an Aruba AP, the following conditions have to be met:
- The AP has to be connected either directly to the controller or to the wired network.
- Upon booting up, a new and unprovisioned AP will seek to acquire its IP address via DHCP. Such step has to succeed.
- The AP will have to be able to discover its master controller in one of the following ways: either via DHCP option 43 or via DNS or using the Aruba Discovery protocol (ADP).
Once an Aruba AP has found its master controller, it will appear in the Master controller AP Database with the following information:
Name: wired mac address
Group: default
IP Address: DHCP assigned IP address
Flags: Inactive (I)At this stage, the AP is ready for provisioning.
Running the command: '#show ap database' will confirm the above facts. Example:
(MM800) #show ap database
AP Database
Name Group AP Type IP Address Status Flags Switch IP
00:0b:86:c0:b7:38 default 65 10.100.135.115 Up 5m:0s I 10.168.82.10
mm-ap61 mm-us 61 10.100.135.113 Up 21h:15m:47s 10.168.82.10
mm-rap70 remote 70 1.1.1.1 Up 21h:16m:9s R 10.168.82.10
Flags: U = Unprovisioned; N = Duplicate name; G = No such group
R = Remote AP; I = Inactive; X = Maintenance Mode; P = PPPoE AP
Total APs:3
Provisioning a single AP:
From the Master controller CLI in enable mode:
- Clear the list of AP's to be provisioned:
#clear provisioning-ap-list
- Go into provisioning mode:
#provision-ap
- Retrieve current provisioning parameters of the AP to be (re)-provisioned (default for new AP's):
#read-bootinfo ip-address <AP_ip-address>
Note: Now the AP goes into the provisioning-ap-list that could be displayed using the command:
#show provisioning-ap-list
Access Points Provisioning List
Current IP AP Name AP Group Location name SNMP sysLocation Master Gateway Netmask IP Addr DNS IP Domain Name Server Name Server IP Antenna gain for 802.11a Antenna gain for 802.11g Use external antenna Antenna for 802.11a Antenna for 802.11g IKE PSK PAP User Name PAP Password PPPOE User Name PPPOE Password PPPOE Service Name Mesh Role Latitude Longitude Altitude Antenna bearing for 802.11a Antenna bearing for 802.11g Antenna tilt angle for 802.11a Antenna tilt angle for 802.11g AP Type Serial # AP State
10.100.135.115 00:0b:86:c0:b7:38 default N/A N/A N/A N/A N/A N/A N/A N/A aruba-master N/A N/A N/A No both both N/A N/A N/A N/A N/A N/A none N/A N/A N/A N/A N/A N/A N/A 65 A90005120 -
Total APs:1
- Copy the AP provisioning parameters into the provisioning workspace:
#copy-provisioning-params ip-addr <AP_ip-address>
- Use the provision-ap options to set the desired values. The most common options are:
ap-name <AP Name> //enclose multiple words in double quotes "
ap-group <Group name> //group name that exists on the controller
fqln <APname.floor.building.campus> //enclosed in double quotes
- Check if the provisioned options are correct:
#show provisioning-params
(MM800) (AP provisioning) #show provisioning-params
AP provisioning
Parameter Value
AP Name mak-ap65
AP Group mak-us
Location name mak-ap65.Floor 1.bldg1.Aruba1344
SNMP sysLocation N/A
Master N/A
Gateway N/A
Netmask N/A
IP Addr N/A
DNS IP N/A
Domain Name N/A
Server Name aruba-master
Server IP N/A
Antenna gain for 802.11a N/A
Antenna gain for 802.11g N/A
Use external antenna No
Antenna for 802.11a both
Antenna for 802.11g both
IKE PSK N/A
PAP User Name N/A
PAP Password N/A
PPPOE User Name N/A
PPPOE Password N/A
PPPOE Service Name N/A
Latitude N/A
Longitude N/A
Altitude N/A
Antenna bearing for 802.11a N/A
Antenna bearing for 802.11g N/A
Antenna tilt angle for 802.11a N/A
Antenna tilt angle for 802.11g N/A
- Push the provisioning parameter to the AP:
#reprovision ip-addr <AP_ip-address>
- The above operation causes the AP to reboot and to come up as a provisioned AP.
AP Database
mak-ap65 mak-us 65 10.100.135.115 Up 39s 10.168.83.10
mm-ap61 mm-us 61 10.100.135.113 Up 21h:32m:16s 10.168.82.10
mm-rap70 remote 70 1.1.1.1 Up 21h:32m:38s R 10.168.82.10
Total APs:3
