Disabling MU in IAP from Aruba central
By esupport posted Apr 09, 2020 03:02 AM
Aruba central should be running in 2.5.x.
How to disable MU/High efficiency for the SSID in Aruba central for IAP.
In Aruba central code 2.5.x, in order to disable MU/High efficiency please go to the SSID advanced settings > Bandwidth control > disabled AC and AX.
With HE enabled
Aruba AP BSS Table
bss                ess           port  ip              phy   type  ch/EIRP/max-EIRP  cur-cl  ap name                      in-t(s)  tot-t      flags
20:a6:cd:xx:xx:xx  Test-IAP  ?/?   169.254.183.48  g-HE  ap    11/19.9/19.9      3       20:4c:03:xx:xx:xxTest-303H  0        6h:45m:2s
wlan ssid-profile Test-IAP
 enable
 index 0
 type employee
 essid Test-IAP
 utf8
 wpa-passphrase 2458bcf1b160f20ff9bc2c2240412614f654bdf6a9173b38
 opmode wpa2-psk-aes
 max-authentication-failures 0
 vlan 10
 auth-server InternalServer
 rf-band 2.4
 captive-portal disable
 dtim-period 1
 broadcast-filter all
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
With HE disabled.
Aruba AP BSS Table
20:a6:cd:xx:xx:xx  Test-IAP  ?/?   169.254.183.48  g-HT  ap    11/19.9/19.9      3       20:4c:03:xx:xx:xx-Test-303H  0        6h:45m:2s
wlan ssid-profile ShweAlex-IAP
 enable
 index 0
 type employee
 essid Test-IAP
 utf8
 wpa-passphrase db74991876281e48fd5799fdf63e0d8ead9eafce68351415
 opmode wpa2-psk-aes
 vlan 10
 rf-band 2.4
 dtim-period 1
 very-high-throughput-disable
 high-efficiency-disable
In the running configuration, you can see “high-efficiency-disable” got pushed post making changes in Bandwidth control.
