Standby APs on active table
By esupport posted Aug 05, 2020 09:19 AM
Q:
Does standby APs list comes in "active AP" table in a controller?
A:
This article applies to all controllers and APs supporting 8.x version.
Starting from 8.x version we will be able to see the standby APs on #show ap active table on the same controller if two or more controllers are present and only if clustering feature is enabled among them.
For example:
AP1’s AAC is controller 1,
AP2’s AAC is controller 2,
a client connect to AP2, and UAC is controller1.
When we perform the #show ap active command on controller 1, it will show both AP1 and AP2.
Verification:
On MD "Controller-2":
(Controller-2) [MDC] #show ap database-summary
AP Database Summary
AP Mode              Total Up  Total Down  Total Upgrading*  Total Rebooting*  RAP Up  RAP Down  RAP Upgrading*  RAP Rebooting*  Active Up  Standby Up
Access Points        737       0           0                 0                 0       0         0               0               367        370
Air Monitors         1         0           0                 0                 0       0         0               0               1          0
Wired Access Points  0         0           0                 0                 0       0         0               0               0          0
Mesh Portals         0         0           0                 0                 0       0         0               0               0          0
Mesh Points          0         0           0                 0                 0       0         0               0               0          0
Spectrum Monitors    0         0           0                 0                 0       0         0               0               0          0
On the above output we have 367 active tunnels. But when you check the #show ap active table you could see the total count as 649.
(MC7220-T2) [MDC] #show ap active | include Num
Num APs:649
When you verify the #show ap active table, it shows APs with standby flag and clients are connected to it. Below is an example.
(Controller-2) [MDC] #show ap active.    ( S indicates the standby flag)
Active AP Table
Name                Group                 IP Address     AP Type  Flags   Uptime      Outer IP  Radio 0 Band Ch/EIRP/MaxEIRP/Clients  Radio 1 Band Ch/EIRP/MaxEIRP/Clients
AP-1             Test           10.0.252.201   315      1Sda    9h:27m:19s  N/A       AP:5GHz-VHT:149+/16.0/33.8/16         AP:2.4GHz-HT:11/14.0/19.5/1
AP-2                Test            10.0.252.82    215      p1Sda   9h:25m:49s  N/A       AP:5GHz-VHT:40-/19.0/23.0/24          AP:2.4GHz-HT:6/19.0/19.0/6
Flags: 1 = 802.1x authenticated AP; 2 = Using IKE version 2;
       A = Enet1 in active/standby mode;  B = Battery Boost On; C = Cellular;
       D = Disconn. Extra Calls On; E = Wired AP enabled; F = AP failed 802.1x authentication;
       H = Hotspot Enabled; K = 802.11K Enabled; L = Client Balancing Enabled; M = Mesh;
       N = 802.11b protection disabled; P = PPPOE; R = Remote AP;
       S = AP connected as standby; X = Maintenance Mode;
       a = Reduce ARP packets in the air; d = Drop Mcast/Bcast On; u = Custom-Cert RAP;
       i = Provisioned as Indoor; o = Provisioned as Outdoor;
       p = Restriction mode in POE-AF/AT;r = 802.11r Enabled; f = No Spectrum FFT support;
       Q = DFS CAC timer running; T = Flex Radio Mode is 2.4GHz+5GHz;
       U = Flex Radio Mode is 5GHz; V = Flex Radio Mode is 2.4GHz; e = custom EST cert; W = Dual 5GHz Mode Enabled; 4 = Using WiFi Uplink
Channel followed by "*" indicates channel selected due to unsupported configured channel.
"Spectrum" followed by "^" indicates Local Spectrum Override in effect.
Channel flags: +/- = 40 MHz, E = 80 MHz, S = 160 MHz, E+E = 80 + 80 MHz (i.e. 36E+149E)
Cluster Role: U = UAC, A = AAC, SU = Standby UAC , SA = Standby AAC
