Environment : This applies to CPPM 6.3 only
From 6.3 onwards, Users can login to the CPPM portal and check the list of supported anti virus programs.
For MAC OS
https://<YOUR_SERVER'S_IP>/agent/supportcharts/Mac_AS_ProductConfig.xml
For Windows.
https://<YOUR_SERVER'S_IP>/agent/supportcharts/Win_AV_ProductConfig.xml
For Linux Machines.
https://<YOUR_SERVER'S_IP>/agent/supportcharts/Linux_AV_ProductConfig.xml
The information provided in the above URLs will be updated as and when CPPM server is updated/upgraded.
The software updates and upgrades are fetched from the below portal.
https://clearpass.arubanetworks.com/cppm/appupdate/cppm_apps_updates.zip.
We can also manually download the package from the portal. Please enter the CPPM subscription key as Username and Password when prompted for authentication.
