Deploy a MM VMC to ESXi
By esupport posted Dec 08, 2016 05:31 PM
Q:
How do I deploy a Mobility Master controller to ESXi?
ASE Link:  Go to the solution
A:
Summary
This solution shows how to deploy and initially configure a Mobility Master 8.0 configuration step by step.  It will demonstrate how to deploy one MM (Mobility Master) as a VMware virtual machine, configure its networking, and license the product.
Software Version(s) Required
AOS 8.0
VMware ESXi 5.5 - 6.0
Configuration Notes
This solution does a walkthrough a network controller within a VM so it has several layers of abstraction.  Pay attention to what network interfaces are referred to and how they are mapped.
Also be aware if improperly configured, the setup can cause a network loop that may shutdown network connectivity within the ESX server.
Platform(s) Tested
ArubaMM (VMware OVA), Version 8.0.0.0
Licenses
None
References
1 comment
1 view
Comments
Dec 28, 2017 03:12 AM
How to get OVA file?
