Enable Ethernet Bonding on Airwave
By Arunkumar posted Jul 11, 2014 06:16 PM
This article talks about enabling Ethernet Bonding on Airwave.
Environment: This article applies to all versions of Airwave which are built on CentOS 6 and greater.
I would like to connect  Airwave server (a physical server) using two NIC’s and enable NIC bonding in CentOS. However, after installing CentOS from the Airwave  ISO file I only seeing one NIC – eth0.
Before going through the configuration, an insight about Ethernet Bonding.
Channel bonding (also known as “Ethernet bonding”) is a computer networking arrangement in which two or more network interfaces on a host computer are combined for redundancy or increased throughput.
mode=0 (Balance-rr) – This mode provides load balancing and fault tolerance.
mode=1 (active-backup) – This mode provides fault tolerance.
mode=2 (balance-xor) – This mode provides load balancing and fault tolerance.
mode=3 (broadcast) – This mode provides fault tolerance.
mode=4 (802.3ad) – This mode provides load balancing and fault tolerance.
mode=5 (balance-tlb) – Prerequisite: Ethtool support in the base drivers for retrieving the speed of each slave.
mode=6 (balance-alb) – Prerequisite: Ethtool support in the base drivers for retrieving the speed of each slave.
Note: Always append extra configuration in case of a rollback.
Configuring Channel Bonding
Login as ROOT to CLI of Airwave and run the below commands.
# cd /etc/sysconfig/network-scripts/
# vi ifcfg-bond0
We’ll be using mode=6 (balance-alb)
Fill in the below details in the file
 DEVICE=bond0
 USERCTL=no
 BOOTPROTO=none
 ONBOOT=yes
 IPADDR=A.B.C.D
 NETMASK=255.255.0.0
 NETWORK=X.X.X.X
 BONDING_OPTS="miimon=100 mode=balance-alb"
 TYPE=Unknown
 IPV6INIT=no
Save and exit.
# vi ifcfg-eth0
Fill the below details in this file
DEVICE=eth0
BOOTPROTO=none
ONBOOT=yes
MASTER=bond0
SLAVE=yes
USERCTL=no
Save and exit.
# vi ifcfg-eth1
DEVICE=eth1
BOOTPROTO=none
ONBOOT=yes
MASTER=bond0
SLAVE=yes
USERCTL=no
Save and exit.
We could add more interfaces to the Bond Interfaces.
Define bonding network interface in /etc/modprobe.d/bonding.conf
# vi /etc/modprobe.d/bonding.conf
Append the following onto the end out your modprobe config file
alias bond0 bonding
Save and Exit.
Restart the Network Services.
# service network restart
After making this change,we must tell Airwave to use the bond0 interface for things like links in email alerts and commands for devices to fetch firmware images from the AMP.
This command will do that:
# dbc "update seas_config set ap_facing_amp_interface = 'bond0'";
3 comments
1 view
Comments
May 26, 2017 08:40 AM
Just to say this works OK but with a couple of caveats:
  1. You cannot use the AMP Setup -> Network GUI page once you have done this (I tested against v8.2.3.1) because the GUI doesn't pick up the IP/mask from the bond0 interface and leaves these fields blank.  You can't commit changes to this page with those fields blank.
  2. Don't try to set the IP/mask in the GUI because if you do it will re-enable the eth0 interface and apply the same IP settings to that as well as bond0
Note that I have bonded eth2 & eth3, and am not using eth0 or eth1 because of the physical setup of my server so the above may behave differently (it may even work!) if eth0 is in your bonded interface.
Oct 05, 2016 07:54 PM
And to have a correct graphic under the AMP -> System -> Performance -> Usage by protocol (bond0) the following file must also be updated, otherwise the graphic will be empty:
# vi /etc/sysconfig/iptables
Change all "eth0" entries to "bond0", the following VI sequence will do that, include the semicolon:
:1,$s/eth0/bond0/g
Save and exit.
Restart the iptables services
# service iptables restart
Aug 11, 2016 06:09 AM
 need to add below command also to get the change reflected in AMP > system > performance page
dbc "update seas_config set system_bw_if = 'bond0'";
