How to customize the Galleria Skin with your own text and images to make the captive portal even better looking.
This video is part of the Aruba ClearPass Workshop series.
- Direct Youtube link -
@Jeff: I typically take a similar resolution as the example files, understanding that it will stretch over the screen on the client. So 1920x1080 is large enough for PCs, 1280x900 is probably fine as well and for mobile only you can go even lower. Then try to compress them so they transfer/load quickly. If you take an original from a digital camera, those can be megabytes and the portal will feel slow. I see the example photos are 150-600kB, slower will get better load times like with websites.
Is there a reccomended size/resolution for replcement pictures in the Galleria skin?
Thanks for letting me know; small human error while copying the video embed code. It is fixed now!
Youtube link says
"This video does not exist".
© Copyright 2021 Hewlett Packard Enterprise Development LPAll Rights Reserved.
