Requirement:AOS Mobility Controller and ArubaOS Switch
Solution:In the following example, IPV6 routing is configured on an AOS mobility controller and an ArubaOS switch.
Configuration:-
--------- IPV6 Interface Mobility Controller Configuration ----------
(StandaloneVMC) [mynode] #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(StandaloneVMC) [mynode] (config) #ipv6 enable
(StandaloneVMC) ^[mynode] (config) #interface vlan 108
(StandaloneVMC) ^[mynode] (config-submode)#ipv6 address 2003:1234::1/124
This configuration change requires a reboot. Do you want to continue[y/n]:y
Mobility Master will be rebooted on write memory.
(StandaloneVMC) ^[mynode] (config-submode)#write memory
Saving Configuration...
Configuration Saved.
---------- IPV6 Interface Switch Configuration ----------
Core-Switch# configure terminal
Core-Switch(config)# ipv6 unicast-routing
Core-Switch(config)# interface vlan 108
Core-Switch(vlan-108)# ipv6 address 2003:1234::2/124
Core-Switch(vlan-108)# write memory
---------- IPV6 Neighbor and Interface Mobility Controller Verification ----------
(StandaloneVMC) [mynode] #show ipv6 interface brief
Interface [Status/Protocol]
vlan 108 [ up/up ]
fe80::c:2900:6ca1:e316/64
2003:1234::1/124
(StandaloneVMC) [mynode] #ping ipv6 interface vlan 108 fe80:0:0:0:5680:28ff:feb4:8440
Press 'q' to abort.
Sending 5, 92-byte ICMPv6 Echos to fe80::5680:28ff:feb4:8440, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.658/1.3694/2.492 ms
(StandaloneVMC) [mynode] #ping ipv6 2003:1234::2
Press 'q' to abort.
Sending 5, 92-byte ICMPv6 Echos to 2003:1234::2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1.046/2.0106/3.198 ms
(StandaloneVMC) [mynode] #show ipv6 neighbors vlan 108
IPv6 Neighbors
IPv6 Addres s Age Link-layer Addr State Interface
fe80:0:0:0:5680:28ff:feb4:8440 18 54:80:28:b4:84:40 REACHABLE vlan 108
2003:1234:0:0:0:0:0:2 46 54:80:28:b4:84:40 REACHABLE vlan 108
---------- IPV6 Neighbor and Interface Switch Verification ----------
Core-Switch# show ipv6 vlan 108
Internet (IPv6) Service
IPv6 Routing : Enabled
ND DAD : Enabled
DAD Attempts : 3
Interface Name : Standalone-VMC
IPv6 Status : Enabled
Layer 3 Status : Enabled
IPv6 Address/Prefixlength Expiry
2003:1234::2/124 permanent
fe80::5680:28ff:feb4:8440/64 permanent
Core-Switch# ping6 2003:1234::1
2003:1234::1 is alive, time = 2 ms
Core-Switch# ping6 fe80::c:2900:6ca1:e316%vlan108
fe80::c:2900:6ca1:e316 is alive, time = 2 ms
Core-Switch# show ipv6 neighbors
IPv6 ND Cache Entries
IPv6 Address MAC Address State Type Port
2003:1234::1 000c29-a1e316 REACH dynamic 9
fe80::c:2900:6ca1:e316%vlan108 000c29-a1e316 REACH dynamic 9
