Setup MSTP On 8320 / 8400 / 8325 VSX
By esupport posted Jul 29, 2019 09:32 AM
1. Aruba OS-CX : Firmware Version 10.02.xxxx
2. Switches in VSX
3. Configuring MST
4. Aruba OS-CX Switches configured as non-root switch.
In 10.2 Multiple MSTP regions are not supported. Multiple instances are supported though
Below parameters should be same on all the switches participating in spanning tree in the network
STP region configuration for MSTP on all the switches in the network (MSTP)
1. config-name
2. config-revision
Additionally, the below needs to be same on VSX Pair switches
STP mode MSTP
STP region configuration for MSTP (config-name and config-revision)
STP instance to VLAN mapping
STP instance priority
spanning-tree config-name Region-One
spanning-tree config-revision 1
Configuration on both VSX Pair
vlan <VLAN Mapping>
spanning-tree spanning-tree priority <Priority>
spanning-tree config-name <Region Name>
spanning-tree config-revision <Revision Number>
show spanning tree MST
