Unit for File size present in "dir" of Controller?
By esupport posted Mar 29, 2017 02:02 AM
Q:
What is the unit of the File size present in "dir" of Controller
A:
The File size present in "dir" of Controller is measured in Bytes.
For Example,
(Controller) #dir
-rw-r--r--    1 root     root     42614784 Mar 28 02:58 crash.tar
-rw-r--r--    1 root     root           58 Mar 28 02:58 crash.tar_md5sum.txt
-rw-r--r--    1 root     root        50823 Mar 28 02:48 default.cfg
-rw-r--r--    1 root     root        50823 Mar 28 02:48 default.cfg_writemem_2017-03-28_02-48-02
-rw-r--r--    1 root     root        50823 Mar 28 02:48 default.cfg_writemem_2017-03-28_02-48-08
drwxr-xr-x    4 root     root         4096 Nov 29 07:04 fieldCerts
-rw-r--r--    1 root     root        58874 Feb 26 00:03 original.cfg
drwx------    2 root     root         4096 Oct 12  2015 tpm
(Controller) #
In the above example, the size of the file for crash.tar is shown as 42614784. Which means it is 42614784 Bytes
 ( which is  approximately 42.62 MB )
