Few clients missing in ALE though they are present in Airwave & controller
By esupport posted Jun 08, 2019 07:33 AM
Q:
Few Clients  missing in ALE though they are present in Airwave and contorller
(024-ARMC-01) #show user-table mac 70:1C:E7:14:7B:C0
Users
    IP             MAC            Name     Role        Age(d:h:m)  Auth    VPN link  AP name       Roaming   Essid/Bssid/Phy                      Profile               Forward mode  Type    Host Name
10.24.36.151  70:1c:e7:14:7b:c0  boan2908  AFK-laerer  00:02:12    802.1x            024-IKT-AP01  Wireless  Akershus-FK/18:64:72:19:6e:32/a-VHT  Akershus-FK-aaa_prof  tunnel        Win 10
can see the access point the client is connected to is active on that controller.
(024-ARMC-01) #show ap active
Active AP Table
Name                     Group       IP Address    11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP    AP Type  Flags  Uptime          Outer IP
024-IKT-AP01             024-Vestby  10.24.36.34   0            AP:HT:11/12.0/18.5   3            AP:VHT:36E/23.0/23.0   225      Ada    23d:15h:5m:40s  N/A
A:
Check whether ALE is calculating the location of the missing client. We need to tail the location log to see whether location is getting calculated for that specific client or not. If location itself is not getting calculated then issue might be due to RSSI value, need to check on deployment side.
#tail –f /opt/ale/ale-location/logs/ale-location.log | grep 701ce7147bc0
2017-11-10 09:37:19.494 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:37:49.627 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:38:30.062 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:38:59.929 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:39:19.335 CET [pool-1-thread-2] DEBUG c.a.a.l.records.StationRecord - TARGET_TYPE_STATION 701ce7147bc0 scheduled with 2 RSSIs:[RssiRecord [rssi=-49, tsSecs=1510303027, bssid=24dec6fa0870, channel=0, classificationType=-1], RssiRecord [rssi=-49, tsSecs=1510303028, bssid=24dec6fa0870, channel=0, classificationType=-1]]
2017-11-10 09:39:19.821 CET [engine-worker-4] DEBUG c.a.a.l.records.StationRecord - New location for TARGET_TYPE_STATION 701ce7147bc0: x=31.966356, y=8.974388, floor=995A5F24F45C3A22AB9921BC38592CA7, algo=ALGORITHM_LOW_DENSITY
2017-11-10 09:39:29.914 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:40:00.096 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:40:30.227 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:41:00.366 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:41:30.579 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:42:00.701 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:42:30.860 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:43:11.087 CET [pool-1-thread-2] TRACE c.a.a.l.handlers.BasicMatrixHandler - Station 701ce7147bc0 reported by unknown BSSID 186472196e30
2017-11-10 09:43:30.256 CET [pool-1-thread-2] DEBUG c.a.a.l.records.StationRecord - TARGET_TYPE_STATION 701ce7147bc0 scheduled with 2 RSSIs:[RssiRecord [rssi=-51, tsSecs=1510303329, bssid=24dec6fa0870, channel=0, classificationType=-1], RssiRecord [rssi=-51, tsSecs=1510303258, bssid=24dec6fa0870, channel=0, classificationType=-1]]
2017-11-10 09:43:30.470 CET [engine-worker-4] DEBUG c.a.a.l.records.StationRecord - New location for TARGET_TYPE_STATION 701ce7147bc0: x=10.036356, y=9.970388, floor=995A5F24F45C3A22AB9921BC38592CA7
In above logs, we see client location is getting calculated by a unknown BSSID, We see such log entrees, if AP details missing in airwave or visualrf. Check whether this particular AP which is reporting this station is added to Airwave and also provisioned in VisualRF. ALE get AP location from VisualRF.
#ALE
