How to telnet Aruba Remote AP?
By AnandKumar Sukumar posted Jul 04, 2014 04:14 AM
Introduction :
Product and Software: This article applies to all Aruba controllers and ArubaOS versions.
NOTE: Aruba OS allows to telnet to AP however Telnet is disable for APs by default and usually there is no need to enable it. Enable Telnet only if instructed to do so by engineering or to do advanced troubleshooting.  Make sure to disable Telnet after the required troubleshooting is complete.
There are three steps to successfully enable telnet for Remote APs.
1. Enable "telnet" under ap system-profile.
2. Allow "telnet" under ap-role
3. Remote AP inner IP address should be routable from telnet source (laptop/desktop).
Network Topology :
User-added image
Configuration Steps :
Step: 1 We have to allow telnet under ap system-profile.
Below from CLI
User-added image
Below from WebUI
Click "Configuration" | Click "All Profile" | Expand"AP" | Expand "AP system" | Select ap system-profile | Enable "Telnet" | Click "Apply" | Click "Save Configuration
User-added image
Step 2: We have to Allow "telnet" under ap-role
Below from CLI
User-added image
Below from WebUI
Click "Configuration" | Click "Access Control" | Click "Policies" | Edit "ap-acl" | Click "Add" | From drop down select "any any service svc-telnet (tcp 23) permit" | Click "Add" | Click "Apply" | Click "Save Configuration"
User-added image
User-added image
User-added image
Step 3: We have to make sure Remote AP inner tunnel address is part of routable subnet instead any un-routable address example 1.1.1.1
User-added image
As above we see this RAP has two IP address
1. 10.13.32.12 (IPsec Inner address)
2. 122.174.101.80 (RAP public address)
We can only telnet to the first address which is IPsec inner address and if that is not routable then we cannot do telnet to the RAP.
If inner address is routable then you should be able to see below prompt after telnet.
User-added image
Verification :
Show commands to verify:
show ap system-profile <profile-name> | include Telnet
show rights ap-role
Troubleshooting :
Verify below points:
If you still unable to do telnet.
1. Do ping or traceroute test from laptop.
If you can ping or successfully traceroute then routing is correct.
2. Make sure between laptop and AP tcp port 23 (telnet) is allowed.
