What is the ACMX exam?
By TrainerGuy posted Nov 22, 2011 03:33 PM
The ACMX (Aruba Certified Mobility eXpert) exam allows you to demonstrate your proficiency in provisioning and troubleshooting a multi-controller network from scratch. The exam proctor provides you with a requirements document describing the network you need to build that demonstrate various core features of an Aruba network.  You may be asked to build this network so that it supports latency sensitive traffic in a highly survivable environment.  You may need to do some troubleshooting. You may need to build firewall policies and user roles.
In the exam, you have an eight-hour exam window to correctly complete the objectives using the Aruba supplied controllers and APs.  (There is a mandatory lunch break for your beneifit.  The lunch time does not count towards the eight hour exam time.) You do not need to provision any third party equipment, but such equipment will be present for you to test and verify.
Additionally, you will need to be proficient with AirWave so it can monitor the Aruba network elements.
The exam is not simple.  But anyone who passed can assert that it is rewarding.
See the attached study guide for more details.
ACMX_StudyGuide.pdf
3 comments
Comments
Aug 07, 2017 03:32 PM
What´s the differente with the exam in pearson vue?
https://certification-learning.hpe.com/TR/datacard/Exam/HPE6-A40
Sep 04, 2014 08:02 AM
Hi!
Is there a new revision of the ACMX exam planned that involves more of the mobility elements present in the aruba solutions? Instant, the MAS, Clearpass, etc?
Nov 30, 2011 07:43 PM
As an existing ACMX, I can attest to the proctored exam's requirement for extensive real-world knowledge.
During my exam, the facilitator intentionally broke some things, left some "details" out, and created sneaky L2 and other issues that made both performance and authentication break.     These are things that happen in the real-world, and if you succeed in obtaining your ACMX, you will have proven your knowledge of not just AOS, but the other components that make the entire "solution" work.
To me this is a much better test of knowledge than memorizing answers for an exam....
