Use a Virtual Controller's template to configure another VC
By Arunkumar posted Jul 11, 2014 05:50 PM
This article explains the changes that need to be made to a Virtual Controller's template when using it to configure another VC's configuration.
Please note that:
>>This is the standard Aruba Instant Configuration template.
>>DO NOT over-write this file
>>Copy & paste this configuration into a new txt file
>>Edit lines in <> as required
Environment:
In a wireless network deployment one might have several Virtual controllers placed in different location.
Using Airwave we can configure the all the VCs using a standard or default template.
Below is a standard template where the changes to be made are in bold and italics.
Based on the network where the VC is being deployed other changes might also have to be made to accomidate the VC in the network.
But for basic configuration the below template will be useful.
version 6.2.1.0-3.3.0
virtual-controller-country <insert 2 character ISO country code here>
virtual-controller-key %guid%
%if ip_address%
virtual-controller-ip %ip_address%
%endif%
%if organization%
organization %organization%
%endif%
%if syslog_server%
syslog-server %syslog_server%
%endif%
ams-ip %manager_ip_address%
ams-key %password%
%server_cert_checksum%
%ca_cert_checksum%
%cert_psk%
name %hostname%
clock timezone %clock_timezone%
rf-band %rf_band%
dynamic-radius-proxy
ams-identity 844460756981198a0fa95e406bd32caf
allow-new-aps
%allowed_aps%
snmp-server community 52064c5c0147bf3bd859b1b9cebe1fa656029b77855817e1
snmp-server community 1cd0feb0f314c424291fb625124e4914d4c6c49ebf107309
arm
 wide-bands 5ghz
 a-channels 36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,36+,44+,52+,60+,100+,108+,116+,124+,132+
 g-channels 1,6,11
 min-tx-power 15
 max-tx-power 127
 band-steering-mode prefer-5ghz
 air-time-fairness-mode default-access
 client-aware
 scanning
syslog-level error ap-debug
syslog-level error network
syslog-level error security
syslog-level error system
syslog-level error user
syslog-level error user-debug
syslog-level error wireless
 mgmt-user netops kcswitch
wlan access-rule default_wired_port_profile
 rule any any match any any any permit
wlan access-rule guestnet
wlan access-rule w197330c513592e
wlan access-rule wired-instant
 rule %ip_address% 255.255.255.255 match tcp 80 80 permit
 rule %ip_address% 255.255.255.255 match tcp 4343 4343 permit
 rule any any match udp 67 68 permit
 rule any any match udp 53 53 permit
wlan ssid-profile w197330c513592e
! enable
 type employee
 essid w197330c513592e
 opmode wpa2-aes
! opmode wpa-tkip,wpa-aes,wpa2-aes,wpa2-tkip
! use the above opmode only when needing to support handhelds which do not support WPA2-AES
max-authentication-failures 0
 vlan 1 <change VLAN number is using VLAN other than 1>
 auth-server <primary windows RADIUS server name - must match WLAN auth server in "Primary RADIUS Server" section below>
 auth-server <backup windows RADIUS server name - must match WLAN auth server in "Backup RADIUS Server" section below>
 rf-band all
 captive-portal disable
 dtim-period 1
 inactivity-timeout 1000
 broadcast-filter arp
 g-min-tx-rate 5
 multicast-rate-optimization
 dynamic-multicast-optimization
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
wlan ssid-profile guestnet
! enable
 type employee
 essid guestnet
 opmode opensystem
 vlan 499 <change if different>
 rf-band all
 hide-ssid
 dtim-period 1
 g-min-tx-rate 5
auth-survivability cache-time-out 24
mgmt-auth-server ustccsec2
mgmt-auth-server ustwa010
mgmt-auth-server-local-backup
!This is the Global TACACS server - do not change
wlan auth-server ustccsec2
 ip 165.28.96.150
 port 1812
 acctport 1813
 key 5d4f50485e4f50483dd092dc0cb96429addc59f2863b1d3ed3de9ec3cc9bb599
wlan auth-server ustwa010
 ip 165.28.32.146
 port 1812
 acctport 1813
!This is the Primary RADIUS Server for Enterprise network authentication
wlan auth-server <primary RADIUS server name>
 ip <ip address>
 port 1812
 acctport 1813
 key 5d4f50485e4f504817a6a8fe41d1544f918ec7062fa1489c79ab3480af6dbfc1
!This is the Backup RADIUS Server for Enterprise network authentication
wlan auth-server <Backup RADIUS server name>
 ip <ip address>
 port 1812
 acctport 1813
wlan external-captive-portal
 server localhost
 port 80
 url "/"
 auth-text "Authenticated"
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
 wireless-containment none
wired-port-profile default_wired_port_profile
 switchport-mode trunk
 allowed-vlan 1,499 <edit allowed VLANs if different>
 native-vlan 1 <edit if requirement is different>
 no shutdown
 access-rule-name default_wired_port_profile
 speed auto
 duplex full
 poe
 type employee
 no dot1x
wired-port-profile wired-instant
 access-rule-name wired-instant
 allowed-vlan all
 no dot1x
 duplex auto
 native-vlan guest
 no poe
 no shutdown
 speed auto
 switchport-mode access
 type guest
enet0-port-profile default_wired_port_profile
enet1-port-profile default_wired_port_profile
enet2-port-profile default_wired_port_profile
enet3-port-profile wired-instant
enet4-port-profile wired-instant
uplink
 preemption
 enforce none
 failover-internet-pkt-lost-cnt 10
 failover-internet-pkt-send-freq 30
 failover-vpn-timeout 180
airgroup
 disable
airgroupservice airplay
 disable
 description AirPlay
 id _airplay._tcp
 id _raop._tcp
airgroupservice airprint
 disable
 description AirPrint
 id _ipp._tcp
 id _pdl-datastream._tcp
 id _printer._tcp
 id _scanner._tcp
 id _universal._sub._ipp._tcp
 id _printer._sub._http._tcp
 id _http._tcp
 id _http-alt._tcp
 id _ipp-tls._tcp
 id _fax-ipp._tcp
 id _riousbprint._tcp
 id _cups._sub._ipp._tcp
 id _cups._sub._fax-ipp._tcp
 id _ica-networking._tcp
 id _ptp._tcp
 id _canon-bjnp1._tcp
#3600
1 view
