Verifying the configuration difference between template and running configuration from Central
By esupport posted Mar 15, 2019 04:21 PM
Q:
Verifying the configuration difference between template and running configuration from Aruba Central
A:
We can use the below method to know central and device configuration difference:
  • Put https://<central_url> /config/device/<deviceserial>/config_details in your browser where Central is authenticated.
  • Replace <central_url> with central url and <deviceserial> with actual switch serial.
This will download a file which will help us to know the running configuration, desired configuration and any errors during your last push from Central.
Below is an example which shows the complete url for a switch with serial number SE44FFF5J1 and the central url used is app2.central.arubanetworks.com
https://app2.central.arubanetworks.com/config/device/SE44FFF5J1/config_details
