HPE IMC - Device Config Backup Task Is Successful But New Config File Not Saved
By esupport posted Feb 28, 2020 05:50 PM
Problem:
HPE IMC - Device config backup task is successful but new config file not saved
Diagnostics:
About HPE IMC Configuration Backup:
  • HPE IMC software allows backup of device running configuration and startup configuration backup
  • It also allows manual backup and auto backup plans which can be scheduled daily, weekly or monthly
  • The configuration backup will be saved to the backup path configured. Default configuration backup path is:
    • C:\Program Files\iMC/server/data/cfgbak
  • If you perform manual backup or have configured auto backup plan, the configuration backup is saved to the above path.
  • However, subsequent backup task is completed successfully but the new config backup is not found under the backup folder.
Solution
A new Configuration file will not be saved:
  • This is not an issue on IMC, this is working normally
  • If DEBUG logs are collected for configuration backup, the below information is noticed:
[DEBUG (0)] [THREAD(1296)] [CCfgFileRestoreTask::processDeviceBackupCompleted()] Delete current config file:10.23.225.13_startup_20200225002452.cfg which is same as last file :10.23.225.13_startup_20200225002138.cfg
IMC does not save the new file as the configuration is matching with the last backup taken
