Instant Dual Uplink
By AnandKumar Sukumar posted Jul 03, 2014 11:23 PM
Introduction : This article outlines the procedure to configure two ethernet uplinks for an Aruba Instant Cluster.
Feature Notes :
Following are the feature notes ::
  • At any point of time; only one port would be active i.e. forward packets
  • With current design (as of 6.3.1.4-4.x); the feature is intended to provide redundancy and it wouldn't be possible to route traffic thru both ports using policy based routing i.e. corp traffic thru one uplink and guest traffic thru another.
Environment : Aruba Instant cluster with two different uplink paths connected to eth0 & eth1 of the APs.
Network Topology : rtaImage.pngConfiguration Steps : With ports plugged into appropriate switches with proper VLAN configuration; below is the configuration needed on IAP end.
Create a new Wired Port Profile
Ensure "Uplink" option is enabled
Configure appropriate VLAN to match switch config.
Save and map the profile to the port.
Set appropriate proirity and failover time under "System --> Uplink".
Answer : With the configuration in place; the AP would be switchover to alternate uplink in case of failure.
Verification :
6c:f3:7f:c5:13:46# show uplink status
Uplink preemption           :enable
Uplink enforce              :none
Ethernet uplink eth0        :DHCP
Ethernet uplink eth1        :DHCP
Uplink Table
Type      State  Priority  In Use
eth0      UP     0         Yes       <---- Before Failure
Wifi-sta  INIT   6         No
3G/4G     INIT   7         No
eth1      UP     1         No
Internet failover           :disable
Max allowed test packet loss:2
Secs between test packets   :2
VPN failover timeout (secs) :180
ICMP pkt sent        :0
ICMP pkt lost        :0
Continuous pkt lost  :0
VPN down time        :0
Uplink Table
eth0      UP     0         No
Wifi-sta  INIT   6         No
3G/4G     INIT   7         No
eth1      UP     1         Yes              <---- After failure of eth0, Eth1 In Use
ICMP pkt sent        :0
ICMP pkt lost        :0
VPN down time        :0
Troubleshooting :
Below are the troubleshooting steps for issues related to dual uplink .
  • Ensure link status; using "show uplink status". If the link isn't up; then focus on troubleshooting link not coming up
  • If "internet failover: is enabled; ensure internet connectivity is available else link would flap over to the alternate uplink
  • If "internet failover" is enabled and config for ICMP check is aggressive; it may result uplink switchover when uplink has performance issues.
  • "show log system" would show information on link switching.
Example ::
 May 30 09:54:06  cli[1742]: <341271> <ERRS> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  ethernet uplink eth0 link down.
 May 30 09:54:06  cli[1742]: <341004> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  stopping DHCP on bond0
 May 30 09:54:06  cli[1742]: <341185> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Retrieving ip address from uplink, ip 192.168.4.104, mask 255.255.255.0.
 May 30 09:54:06  cli[1742]: <341274> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Update election ip from br0, election ip 192.168.4.104/255.255.255.0.
 May 30 09:54:06  cli[1742]: <341004> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  build_my_ip_address: old ip and new ip same; skipping
 May 30 09:54:06  cli[1742]: <341167> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Uplink eth0 type Ethernet, state UP->DOWN.
 May 30 09:54:06  cli[1742]: <341177> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Try next uplink because current uplink is down - Ethernet.
 May 30 09:54:06  cli[1742]: <341168> <INFO> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  get_lower_uplink,752: uplink type Ethernet, state UP.
 May 30 09:54:06  cli[1742]: <341263> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  enable uplink eth3.
 May 30 09:54:06  cli[1742]: <341167> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Uplink eth3 type Ethernet, state UP->PROBE.
 May 30 09:54:06  cli[1742]: <341265> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  enable ethernet uplink eth3.
 May 30 09:54:06  cli[1742]: <341265> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli[1742]: <341004> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  ifenslave bond0 eth3
 May 30 09:54:07  cli[1742]: <341004> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  uplink is down, cannot be enabled.
 May 30 09:54:07  cli[1742]: <341168> <INFO> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  swarm_select_uplink,1333: uplink type Ethernet, state PROBE.
 May 30 09:54:10  cli[1742]: <341272> <ERRS> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  ethernet uplink eth3 link up.
 May 30 09:54:10  cli[1742]: <341167> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Uplink eth3 type Ethernet, state PROBE->UP.
 May 30 09:54:10  cli[1742]: <341181> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Uplink eth3, setup ip for uplink - Ethernet.
 May 30 09:54:10  cli[1742]: <341004> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  bring up dhcp client for ethernet uplink
 May 30 09:55:11  cli[1742]: <341004> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  /etc/setup_ip_swarm Ethernet 1
 May 30 09:55:11  cli[1742]: <341166> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Get interface br0 ip: 0.0.0.0/0.0.0.0.
 May 30 09:55:11  cli[1742]: <341005> <ERRS> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  ethernet up without ip address, setup ip now
 May 30 09:55:11  cli[1742]: <341005> <ERRS> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  ethernet uplink couldn't comeup, ip not set
 May 30 09:55:11  cli[1742]: <341264> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  disable uplink eth3.
 May 30 09:55:11  cli[1742]: <341167> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Uplink eth3 type Ethernet, state UP->DOWN.
 May 30 09:55:11  cli[1742]: <341006> <CRIT> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  route delete default
 May 30 09:55:11  cli[1742]: <341185> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Retrieving ip address from uplink, ip 192.168.4.104, mask 255.255.255.0.
 May 30 09:55:11  cli[1742]: <341274> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Update election ip from br0, election ip 192.168.4.104/255.255.255.0.
 May 30 09:55:11  cli[1742]: <341004> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  build_my_ip_address: old ip and new ip same; skipping
 May 30 09:55:11  cli[1742]: <341177> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  Try next uplink because current uplink is down - Ethernet.
 May 30 09:55:11  cli[1742]: <341263> <WARN> |AP 00:0b:86:8f:38:10@192.168.4.104 cli|  enable uplink .
3 comments
Comments
Apr 17, 2019 01:12 AM
Now I''ve deployed to a remote site. I'll redo as your suggestion.
Apr 16, 2019 01:09 AM
Can you configure native-vlan as 1 and try?
wired-port-profile WAN2
 switchport-mode trunk
 allowed-vlan all
 native-vlan guest   <<<<<<
Apr 02, 2019 09:27 AM
I've tried with your suggestion, but didn't work. I'm using Aruba IAP 8.4.0.0 in cluster with UAP303. I enabled the 2nd uplink and set up followed your steps. When using a command, shown only eth0 up (see picture). Also attached some part of configuration. Any other choice, please.
wired-port-profile wired-SetMeUp
 switchport-mode access
 allowed-vlan all
 native-vlan guest
 no shutdown
 access-rule-name wired-SetMeUp
 speed auto
 duplex auto
 no poe
 type guest
 captive-portal disable
 no dot1x
wired-port-profile default_wired_port_profile
 allowed-vlan all
 native-vlan 1
 shutdown
 access-rule-name default_wired_port_profile
 speed auto
 duplex full
 no poe
 type employee
 no dot1x
 allowed-vlan all
 native-vlan guest
 uplink-enable
 trusted
 no shutdown
 access-rule-name WAN2
 speed auto
 duplex auto
 no poe
 type employee
 auth-server InternalServer
 no dot1x
enet0-port-profile default_wired_port_profile
enet1-port-profile WAN2
uplink
 preemption
 enforce none
 failover-internet
 failover-internet-pkt-lost-cnt 10
 failover-internet-pkt-send-freq 30
 failover-vpn-timeout 180
 uplink-priority ethernet 2
 uplink-priority wifi 3
 uplink-priority cellular 4
 uplink-priority ethernet port 1 0
