Portfast-trunk on AP wired port
By esupport posted Oct 18, 2016 07:38 PM
Q:
How to enable Portfast-trunk on AP wired port ?
A:
Points to remember:
  • Spanning Tree should be enabled on the access point before enabling PortFast.
  • If PortFast is configured, it is enabled only on access mode ports and if PortFast-Trunk is configured, it is enabled on trunk-mode ports only. Only one of them can be set based on the port’s switchport mode.
Follow the steps below to enable PortFast/PortFast Trunk through the WebUI and command line.
In the WebUI
1. Navigate to Configuration > Advanced Services > All Profiles.
2. Click profile AP > AP wired port.
3. Select the AP profile to enable PortFast.
4. Select the Portfast checkbox.
Ensure the Switchport mode is access by changing the value in the Basic tab of the AP.
5. Click Apply.
Enabling PortFast On Trunk:
In the WebUI
3. Select the AP profile to enable PortFast on trunk.
4. Select the Portfast on trunk checkbox.
Ensure the Switchport mode is trunk by changing the value in the Basic tab of the AP.
5. Click Apply.
In the CLI
Execute the following commands in config mode to enable PortFast.
Before enabling PortFast ensure that the switchport mode is set to access using the ap wired-ap-profile command.
(host)(config) #ap wired-port-profile "default"
(host) (AP wired port profile "default") #portfast
To disable PortFast execute the no portfast command in the config mode.
(host) (AP wired port profile "default") #no portfast
The following example displays the spanning tree information of an AP, using the CLI command:
(host) (config) #show ap wired-port-profile <ap-name>
Execute the following commands in config mode to enable PortFast on trunk.
(host) (AP wired port profile "default") #portfast on trunk
To disable PortFast on trunk execute the no portfast on trunk command in the config mode.
Before enabling PortFast on trunk ensure that the switchport mode is set to trunk using the ap wired-approfile command.
