How To Find OID For CPU On 8400 Switch
By esupport Unpublished
We have users requesting for SNMP OID values for CPU on the Halon switches.
Multiple request have come across from customer to monitor their switch via SNMP NMS
This is the SNMP MIB for the CPU utilisation.
Note that it has 8 entries because the 8400 consists of 8 cores and the Utilisation is given for each of the cores.
# snmpwalk -v 2c -c public 127.0.0.1 .1.3.6.1.2.1.25.3.3.1.2
HOST-RESOURCES-MIB::hrProcessorLoad.196608 = INTEGER: 15
HOST-RESOURCES-MIB::hrProcessorLoad.196609 = INTEGER: 12
HOST-RESOURCES-MIB::hrProcessorLoad.196610 = INTEGER: 18
HOST-RESOURCES-MIB::hrProcessorLoad.196611 = INTEGER: 16
HOST-RESOURCES-MIB::hrProcessorLoad.196612 = INTEGER: 14
HOST-RESOURCES-MIB::hrProcessorLoad.196613 = INTEGER: 18
HOST-RESOURCES-MIB::hrProcessorLoad.196614 = INTEGER: 12
HOST-RESOURCES-MIB::hrProcessorLoad.196615 = INTEGER: 13
This is the SNMP MIB for the CPU utilization.
Note that it has 8 entries because the 8400 consists of 8 cores and the Utilization is given for each of the cores.
How do we know which of the CPU is which?
As you can see 196608-196615 are the 8 CPU cores listed in order and the hrPRocessorLoad gives the utilisation for each of these.
# snmpwalk -v 2c -c public 127.0.0.1 .1.3.6.1.2.1.25.3.2.1.3
HOST-RESOURCES-MIB::hrDeviceDescr.196608 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196609 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196610 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196611 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196612 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196613 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196614 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
HOST-RESOURCES-MIB::hrDeviceDescr.196615 = STRING: GenuineIntel: Intel(R) Xeon(R) CPU D-1527 @ 2.20GHz
1 view
