L2 GRE Tunnel between Aruba Controller and Mobility Access Switch(MAS)?
By esupport posted May 04, 2016 02:52 PM
How to setup  L2 GRE Tunnel between Aruba Controller and Mobility Access Switch(MAS)?
Layer-2 GRE tunnels allow us to have the same VLAN in multiple locations (separated by a Layer-3 network) and be connected. The forwarding method for a Layer-2 GRE tunnel is bridging.
However, the drawback of using Layer-2 GRE tunnels is that all broadcasts are flooded through the tunnel, adding traffic load to the network
Configuration on CLI
    SYNTAX
        Controller
        interface tunnel <id>
            description <description>
            tunnel mode gre 0
            tunnel source <Controller-ip vlan>
            tunnel destination <switch-ip>
            trusted
            tunnel <vlan to be tunneled>
        MAS
        interface tunnel ethernet <id>
            switching-profile "vlan to be tunneled"
            source-ip <Switch-ip vlan>
            destination-ip <Controller-ip>
    EXAMPLE
        Controller
        interface tunnel 1
            description "Tunnel Interface"
            tunnel mode gre 0
            tunnel source vlan 193
            tunnel destination 10.17.169.226
            trusted
            tunnel vlan 50
        MAS
        interface tunnel ethernet "1"
            switching-profile "vlan50"
            source-ip vlan 185
            destination-ip 10.17.170.227
1. Check the output "show ip interface brief" and the tunnel interface should show UP.
2. Ping either side of the L3 tunnel interface and it should be pingable.
3. Connect a laptop  on either sides and ping each other and it should ping.
